跳转到主内容
加入维修社区 - 创建账户
Toshiba Satellite L50D-B 是一款笔记本电脑,属于 Toshiba Satellite 系列。
How to remove the internal SSD?
The internal SSD is not using the normal SATA connection, I have the backplate off. There are rubber corners around the SSD too.
Update (05/28/23)
. Photo
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I added a photo but I am unsure if it posted.
由完成的
添加一条评论
1个答案
已选择的解决方案
You should be able to just slide it out as shown in the attached picture. After you pull it out, you may find that the drive really is a SATA drive, just connected in a wonky connector. I was taking apart a laptop the other day that had a ribbon cable attached to an adapter that attached to a SATA connector on the drive. Just give it a go and let us know how it goes.
Good luck!
这个答案有帮助吗?
得分 1
2条评论:
That works thanks!
由完成的
You're very welcome! I'm glad my tinkering was able to help someone! :)
由完成的
添加一条评论
添加你的答案
SaltyAsterisk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 426
