My sony cyber shot dsc s750 is not turning on
recently found my cyber shot dsc s750, bought new batteries, charged it, still wont turn on. is it because i havent used it for years? pls help
@rosiep time to take your camera apart. Check for corrosion, disconnected, torn ribbon cables, check the main board for odd looking components. Your camera actually has two fuses. One is the power fuse and one is the charging fuse. Check for continuity with a multi-meter. Once you have your camera apart, post some good pictures with your question. 在已经存在的问题里加入图片 That will allow us to see what you see. Use this document Sony DSC S750 SM to work on your camera
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 80
总计 1,035
Remove batteries and examine all battery connectors for oxidation and/or corrosion. A pencil eraser or mild scrubbing pad can remove corrosion and may allow full battery voltage to power up your cyber shot.
由 F Dryer 完成的
@notbroken connectors are all good. tried cleaning it too just to be sure but it still didn't work
由 rosie p 完成的
The Sony site mentions when the camera isn't used for a period of time, recharging the battery is needed. "After putting in the battery, it may take a few minutes before the power turns on because the camera status is being checked. This is not a malfunction." There's an internal rechargeable battery for clock and memory that gets recharged from the main battery. This shouldn't interfere with powering on the camera. You can try recharging the battery again and see if the camera powers up. I think this is a battery issue and not a 'bricked' camera electronics. I have a very old Nikon Coolpix 2500 and it still works but I have to recharge the battery before use. Similar removable battery pack for recharging in its charging cradle.
由 F Dryer 完成的
@notbroken hey thanks for your help we've tried recharging the battery but as of now its still not turning on
由 rosie p 完成的
