跳转到主内容
加入维修社区 - 创建账户
Valve Steam Controller (Steam 手柄)于 2015 年 11 月 10 日发布。型号为 1001。
Repair or replace the back cover
So this is pretty incredible. After years of using the Steam Controller regularly, the two top pieces of the back cover finally snapped off, like baby teeth. One of the pieces even ended up inside the controller!
I'm not sure there's any chance I can repair this cover considering this is molded plastic, but is it possible to replace the back cover? As is, the back cover does not sit nicely in the controller. Only the spring-loaded lever at the bottom is holding it in. While it can still cover the batteries, it's very difficult to press the grip buttons with this grip as is without some reinforcement to hold the top of the grip to the back of the controller.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
According to the teardown, removing the battery cover and the rear part of the controller is easy; just search for spare parts online (if it is only the battery cover, there is also a 3D-printable one)
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
According to the teardown, removing the battery cover and the rear part of the controller is easy; just search for spare parts online (if it is only the battery cover, there even is a 3D-printable one)
这个答案有帮助吗?
得分 1
2条评论:
The link to the 3D printed back is a godsend. Thank you so much.
由完成的 分享
@markray56334 you're welcome :)
由完成的 分享
添加一条评论
添加你的答案
Damian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 1,077
