跳转到主内容
Samsung 75″ Class 4K UHD (2160P) Smart LED TV (UN75JU641DFXZA)
7 个问题 查看全部
Broken Bezel - Poor picture and color quality - middle to right edge.
Hello Leaders! Could someone kindly let me know if this can be fixed (please see attached photos).
ISSUE: The TV was not dropped, however, the bezel was broken during transport. Now the picture is of the poorest quality particularly on the right side of the screen.
I'm pretty technical and willing to make the repair myself, being that this TV is 6 years old. I simply need a service repair manual and a parts house, of which I've been unsuccessful finding online.
Any helpful guidance would be gracious as this is my primary family room tv.
Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@marshalj looks like you got a couple of thins going on here. First, clarify if this.
In the red box, are those lights a reflection from when you took the picture or are they always on your screen? If they are, then you have a damaged backlight strip there are diffusers on the LEDs that will have come off, this leaving this type of light. Next is the damage to the screen on the right side of the picture, marked with a blue box. That looks like bad signal form the gate drivers to the panel. Check the thin ribbon cables that attached to the actual panel. Gently press on them and see if that changes the image. You are looking for something like this
but not exactly since these are obviously form a different TV.
It looks to me like there is a bit more damage than you may suggest. Take the back cover off and evaluate all ribbon cables and all boards. REseat the ribbon cables. Check for tears and broken components. These could be as simple as a bad main board/T-con board to as complex as a broken panel/LCD driver boards. Once you have the back cover off, post some good pictures with your question so we can see all the boards.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Marshal J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 170
