跳转到主内容
加入维修社区 - 创建账户
HP 15 系列笔记本电脑(特别是 15-ef 型号)的维修和拆解信息。HP 15-ef 是一款经济型笔记本电脑系列,配备 15.6 英寸触摸屏、AMD 处理器、DDR4 内存和固态硬盘。可通过以 15-ef 开头的型号进行识别。
Color changes on screen
A few days ago, I boot my PC and I realized the screen has changed from it normal color to a pinkish color . I want to know how to get rid of it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
My first suspect would be the video cable. If you can (with it powered off), disconnect & reconnect the cable and then try rebooting the laptop.
The ribbon cable (usually located on the back side of the LCD). Sometimes just reconnecting it will do the trick. If not I would suggest to replace the cable before any other parts (it should be relatively inexpensive.)
The connectors are fairly fragile, so be gentle with it or watch a YouTube video on LCD replacement for your model (i'd skip to the relevant parts)
这个答案有帮助吗?
得分 0
添加一条评论
La pantalla de mi pc se pixeleo y se coloco con un tono rosa, ya trate de reiniciarla, hasta la apague y deje descansar pero sigue igual.
Si le tomo una captura se pantalla o algo por el estilo se visualiza normal.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ari Know 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 49
总计 553
