跳转到主内容
加入维修社区 - 创建账户
Velop 网状 WiFi 系统可支持多种 WiFi 设备。它采用 Intelligent Mesh™ 技术,可为任何类型和大小的住宅提供最快的互联网连接路径。
My wifi strength is weak .
Can the antenna be replaced or can I use a coil to. Improve it ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hey buddy , having issues with WiFi strength?
Try this.....
  • Update your router's software.
  • Use a strong WiFi password. It may be leaked.
  • Use a Wi-Fi range extender if your router's signal doesn't reach all areas of your place.
If above things would not work,
  • Consider upgrading your router if it's old or doesn't support the latest standards.
  • Check if any devices on your network are using a lot of bandwidth.
  • {Temporary Fix]} Downloads, streaming, and file-sharing can hog the Wi-Fi. Close unnecessary apps or limit their usage.
If nothing works, get in touch with your internet service provider (ISP). They might be able to help you further or troubleshoot any connection issues.
Give these tips a try, and hopefully, your Wi-Fi will get stronger.
Parsu Tayade,
Independent Advisor.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Martin Griffith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 529
