Jeep Cherokee 87 won't start
1987 Jeep Cherokee Limited four-wheel drive won't start turns over gets fuel has new coil parked it after work went out in the morning wouldn't start ran day before
Rutor,
This almost certainly has to do with your coil or coil wires just based on your description of it happening after a rainfall. Since you just replaced the coil, let’s assume that is good. So, I’d suggest buying a new set of plug wires and the wire that goes from the coil to the distributor (if it is separate…sorry i don’t know this engine by heart). Or, the wire that feeds the coil (12VDC) might be shorting out. Best of luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 326
1条评论
@rutor1 did you check for spark on all cylinders? What else did you check?
由 oldturkey03 完成的
