跳转到主内容
加入维修社区 - 创建账户
The Buick Lucerne is a full-size upscale sedan sold by Buick from 2006 to 2011.
blows fuse when trying to crank
When I try and crank the engine the 40 amp fuse for the crank blows immediately
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You have a short circuit. Disconnect the solenoid wire for the starter and try cranking again. Of course the engine will not crank but if the fuse does not blow then you need a new solenoid. If the fuse still blows the short is in the wiring. Inspect and repair as required.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raymond Febles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 321
