跳转到主内容
加入维修社区 - 创建账户
苹果第五代智能手表,可选蜂窝网络版本,于 2019 年 9 月 20 日发布。
Best Non OEM Replacement Screen?
Subject is an Apple Series 5, 40 MM watch with a cracked screen. I can still see the icons.
Do I need anything more than a replacement screen kit to fix this?
There are multiple screen kits available ranging from $10 to over $200. Which is the best bang for the buck. It doesn't make sense to buy a $139 screen kit for a watch that old.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
you should link the one you're interested in so we can take a look at it.
由完成的
Looking at this one Apple 5-40mm
由完成的
@stanleybunch this isn't a full display, its only the digitizer and front glass, so if you have LCD problems, or problems with the backlight, this won't fix it unfortunately :(
由完成的
添加一条评论
2个答案
@stanleybunch - That link is only the crystal/digitizer part it’s not the OLED panel part which is glued to the crystal/digitizer part. That’s why it’s so cheap (note they called it an LCD which it’s not)
I really don’t recommend attempting ungluing the OLED as more often than not you just end up killing it. It’s better to get the full assembly.
这个答案有帮助吗?
得分 0
添加一条评论
Buy a complete screen assembly, they aren't cheap. If you don't want to spend a lot then I'd bang it on ebay as spares or repairs and let someone else have a go. OR, look on ebay for the same watch locked to icloud and use the screen off it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stanley Bunch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 866
