跳转到主内容
加入维修社区 - 创建账户
第十代 Apple iPad 的维修指南、拆解和故障排除信息,有 Wi-Fi 和蜂窝网络版本,存储容量为 64 GB 或 256 GB。于 2022 年 10 月发布。通过型号 A2696、A2757、A2777 或 A3162 进行识别。
Heating issue/screen brightness effected
Could it be possible to give me the dimensions of where the logic board is so I can place some heatsinks to try and keep ipad cooler so the screen don't keep reducing brightness. I'm sure it's a heat issue as once temperature is reduce the brightness of screen returns to normal.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Here's a picture of the iPad 10 without the screen. I've marked out the logic board in the picture; basically if you cool the right edge of the iPad that's where the heat is going to be coming from.
The picture is oriented so you'd be looking at it with the charging port on the bottom.
这个答案有帮助吗?
得分 4
2条评论:
cheers. Planning to use akasa double-sided thermal conductive tape. I have plenty of small chipset blue heatsinks that should help handle the heat. Poor cooling design on expensive device. Apple solution is to close down apps to reduce processor usage which bring down heat.
由完成的 分享
@robmods you might want to consider using a 0.3 mm Copper Shim Thermal Pads and some Kapton Tape with your heatsinks. Typically these are used for copper modding graphics cards, but I'm willing to bet that they would work really well in your iPad.
由完成的 分享
添加一条评论
添加你的答案
Robmods 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 532
