跳转到主内容
加入维修社区 - 创建账户
2012-2018 款 Ford Focus 为北美市场推出的第三代车型。高性能版本包括 Focus ST (2012-2018) 和 Focus RS (2016-2018)。
How do I fix gearbox problem
How do I fix fordfocus 2012 gearbox problem and overheating
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Need you to be ALOT more specific. What gearbox problem? And what is overheating? Are they 2 separate issues?
由完成的 分享
Actually they are two separate issues. As regard the gearbox while driving it suddenly gets to a point I can't accelerate anymore.. it automatically goes to neutral gear. I need to rest the car for about 10mins or more before it enters D drive.
The message on the dashboard reads transmission hot wait 5mins
由完成的 分享
I suggest searching Ford Focus forums where owners and sometimes Ford techs share knowledge.
由完成的 分享
How do I fix my dual clutch in an automatic transmission
由完成的 分享
添加一条评论
1个答案
In 2014, Ford started putting dual clutch standard transmissions in their vehicles which are electronically controlled to act like automatic transmissions. There are two pins inside the transmission that each operate one of the clutches. These pins get stuck and when that happens it's like the driver is riding the clutch. This wears down the clutches and that is what causes the heat.
I had this very same problem with my 2018 Ford Focus with the very same symptoms. On Christmas Eve 2024 the transmission shut the car down. I had to limp it home one increment at a time. Like yours did to you, mine would overheat and shut down. It would take 20 minutes to cool down enough to go the next leg towards home.
Ford wanted too much money to fix the problem so I found a shop that would actually fix it for much less money - about half of what Ford wanted. Ford has known about this problem for a very long time and has been sued several times over it and still will not issue a recall. One of those law suits was even the State of California who filed a class action against Ford and won. Even with that, Ford refuses to issue a recall.
Please accept my apologies for not being able to offer advice on how to actually fix this problem. But, knowing precisely what the problem actually is will be of great assistance in finding the cure. You have my best wishes in finding that cure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 674
