跳转到主内容
加入维修社区 - 创建账户
第四代 Fairphone 手机,由同名社会企业制造。于 2021 年 10 月发布。
Phone call or receive problems!
Everytime, I make a phone call or received a phone call. There other side how call me is not able to hear my voices. Help to fix FairPhone 4. Do you think is the speaker part is the problem?
Update (05/13/23)
Which part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
https://www.google.com/amp/s/amp.theguar...
Which part?
I try to put the image is not working well. So, put a link.
完成的
添加一条评论
2个答案
已选择的解决方案
No you have a problem in your Microphone, you should replace it.
这个答案有帮助吗?
得分 0
1条评论:
The speaker and microphone are the same part or component?
完成的
添加一条评论
最有帮助的答案
Hi @erickonix,
Can you be heard OK when using the phone in loudspeaker mode when on a call?
Is the phone in a protective case at all? If so remove from the case and check if it now works OK.
Try using a vacuum cleaner to clear the voice inlet hole located on the bottom edge of the phone in case it is blocked with lint etc, and check.
If still no good it may be the microphone in the phone.
这个答案有帮助吗?
得分 3
15条评论:
Even with or without the phone case still same problem. Where is located the microphone?
完成的
@erickonix
Did you try clearing the voice inlet hole using a vacuum cleaner, you didn't say?
完成的
Can you show me as pictures where is located?
完成的
@erickonix
Can't find any pictures but there are two small holes on the bottom edge of the phone for the microphone.
Do not stick a pin in them to see if they're clear as you may damage it
There's also a small hole at the top for another microphone which is used for loudspeaker calls
完成的
In bottom part of FairPhone 4. In the center bottom is USB type C. At the right side of USB type C have 3 holes. At the left side is have small hole. So, which part is the microphone?
完成的
显示更多的10条评论
添加一条评论
添加你的答案
erickonix 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 38
总计 1,993
