跳转到主内容
The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
How to change faulty USB port
I have an issue which relates to the micro usb port on my Nexus S not working.
How hard or easy is it to change the port ?
I've looked at the disassembly here on the website and did not manage to see clearly how the USB port was connected to the board.
Best regards,
Daniel
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I also have a problem with my USB port which I think might be solved by replacing it. Phone works as normal but I'm unable to charge or connect it to a computer via its USB port.
Just wondering if the original poster or anyone else tried replacing the USB port and how easy/hard it was?
完成的
添加一条评论
1个答案
已选择的解决方案
Daniel Manolache, it is soldered onto the board and will require soldering to replace. The part itself is inexpensive so if you are hesitant to do it yourself, you might want to try a local TV repair shop. Parts are available at places like this
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Daniel Manolache 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 12
总计 7,144
