Tv is getting off in just few seconds of start
Tv turns on normally but automatically it getsoff and there is no picture or sound.
@gulab_1670 your model a KDL-32EX700? First you need to verify that you have no image on all inputs. If your screen remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, with the TV in it's "presumably" on position, use a flashlight and angle the light beam against the screen.See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 9
总计 24
