跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
DS won't calibrate correctly on one side of the screen.
Hi! I've recently switched out the bottom screen of my DS because it was dying. The replacement screen however seems weird. Input is a lot to the left although I touch somewhere on the right. Calibration isn't working properly and only lets me go round and round for eternity unless I misinput on the bottom right point or entirely, but that's not the point of the calibration.
The left two points are always rightly calibrated, but the right ones are either very far to the left or to the right. The screen and rims are clean. Can someone help? I don't want to waste any more hours on the calibration screen :(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
In case the question pops up - no cables are damaged or falsely connected, connectors are also all clean. I've taken my DS at least 20 times apart just to see what the issue is and I'm getting more and more frustrated :(
完成的
添加一条评论
1个答案
最有帮助的答案
By "bottom screen" do you mean the LCD, digitizer, or both? If you only swapped one, check that the digitizer is properly aligned with the LCD. It's a long shot, but the other cause would most likely be a bad digitizer, so I'd say it's worth checking. If it's aligned and the problem persists, you'll probably need to replace the digitizer
这个答案有帮助吗?
得分 1
1条评论:
I meant the digitizer, sorry! It's 100% correctly aligned. I've swapped both just to be safe. Am getting a replacement digi, hope it'll be fixed, if not I'LL cry
完成的
添加一条评论
添加你的答案
Yuka is Sleepy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 331
