跳转到主内容
加入维修社区 - 创建账户
Singer EZ-Stitch 链式缝纫机旨在帮助初学者完成有趣且富有创意的项目。它可用于缝制手工艺品、衣物、靠垫、配饰等。
How to remove the needle
How do I replace the needle. My model had a plastic needle protector with no screw. How do I remove this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Shauna
To remove the needle from the Singer EZ-Stitch Chainstitch Sewing Machine, follow these steps:
  1. Unplug the machine and remove the needle plate by unscrewing the screws that hold it in place.
  2. Loosen the needle clamp screw by turning it counterclockwise using a small screwdriver or the included screwdriver that came with the machine.
  3. Once the needle clamp screw is loose, carefully pull the needle out of the clamp. Be sure to note the orientation of the needle so that you can insert the new needle correctly.
To replace the needle on the Singer EZ-Stitch Chainstitch Sewing Machine, follow these steps:
  1. Make sure that the machine is unplugged and that the needle clamp screw is loose.
  2. Insert the new needle into the clamp, making sure that it is facing the correct direction.
  3. Tighten the needle clamp screw by turning it clockwise using a small screwdriver or the included screwdriver that came with the machine.
  4. Replace the needle plate by screwing it back into place.
If your model has a plastic needle protector with no screw, you can remove it by gently pulling it straight out from the machine. Once the protector is removed, you can follow the above steps to replace or remove the needle as needed.
or
you can refer to this video
link:- https://youtu.be/K11bofV8Ov0
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shauna 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 15
过去 30 天: 41
总计 617
