跳转到主内容
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
383 个问题 查看全部
My iMac 2390 won’t turn on
My sons 2010 imac 27” hasn’t been turned on in 5 years. Worked before that. I turned it on today and nothing turned on. I removed the lcd screen to gain visual access to th diagnostic LEDs and saw the number 1 LED was on. I pushed the power button and the number 2 LED blinked and then both 1 and 2 shut off. I removed power and repeated only this time I shorted the power switch on the board and got the same result.
I tried holding the power button for 1 min with and without power cord and no change.
Given that it worked before not using it it for an extended period I’d be surprised if the power supply board went bad but of course it’s possible.
Anything else I should try?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@emdoller yes, that sounds like a bad power supply. Check the cables to the logic board. Make sure that they are properly connected etc. Also, check the power supply. I would not bet surprised to find some degraded or even leaky capacitors. After that you can try and measure some voltages.
If unsure, you can always post some pictures of your PSU with your Question. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emdoller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 65
