跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
286 个问题 查看全部
Use a late 2015 27" Retina EMC 2834 Display as a Replacement
I have accidentally cracked my 2017 27" Retina iMac and actually have a 2015 27" Retina iMac. Wondering if anyone has any insight as to whether I could replace the 2017s display with the 2015?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The 2015 iMac screen is not compatible as it’s just a standard Retina not a 5K Retina screen. The cable connection between the logic board and display needs to carry many more lines of data.
这个答案有帮助吗?
得分 1
6条评论:
this is a late 2015 Retina 5k iMac, A1419 EMC 2834
完成的
@hfosteriv - Let compare the displays of the two 5K displays:
The late 2015 P/N 661-03255 and the LG P/N LM270QQ1 (SD)(B1)
And for the 2017 P/N 661-07323 and the LG P/N LM270QQ1 (SD)(C1)
So they do appear to be the same from the LG perspective the last code is the screens brightness as the 2017 has a higher NITS value.
完成的
interesting, I will do this over the weekend and post the results - I am not afraid of a little adventure!
完成的
@hfosteriv - Make sure to review the guide and use the special cutter as you can damage the display if you are the careful and besides you’ll need a fresh adhesive tape kit
2017年款27寸 iMac 显示屏更换
iMac Intel 27" (2012-2019) Adhesive Strips
iMac 27" 2017 Adhesive Strips Replacement
完成的
absolutely! you are great1
完成的
显示更多的1条评论
添加一条评论
I have a simmilar situation, did this swap
Worked?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charles Foster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 44
