Correct Torx size for acer swift 3 314-57
Hi, I'm wondering if anyone knows what is the correct torx size to open the bottom panel on the acer swift 3 314-57 as I want to ensure I buy a tool set with the right size bit. Thanks
@oliverlang those are T6 screws. You can use this kit Mako Driver Kit - 64 Precision Bits and it does not have a T6, it has the TR6. That is the security screw version and will fit as well. If you do a lot of work, or want to get into doing more, I'd get this kit Manta Driver Kit - 112 Bit Driver Kit It'll last you a long time and really has all the drivers you'll need.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 34
总计 277
