跳转到主内容
加入维修社区 - 创建账户
OnePlus 8 Pro 是 OnePlus 于 2020 年 5 月发布的一款安卓智能手机。本页面涵盖了区域型号 IN2023 和安卓构建名称 OnePlus8Pro。
Fingerprint Sensor Not Working After Screen Replacement
So yesterday I had my screen replaced (was grenaded after it met my bed frame edge) and it all went perfectly fine. The only thing that bothers me now is the fingerprint reader. I can register new fingerprints without a hitch like normal, so I know it's working fine, but after setup my fingerprint just doesn't work, like something is suddenly making it not read. Has anyone else ran into this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
7个答案
最有帮助的答案
If you transferred the original finger print sensor from the old display to the new one, it typically requires recalibration. If not, then the finerprint sensor is programmed to that specific device and a new or replacement one won't work without reprogramming it. As far as I know, oneplus doesn't make the reprogramming software publicly available. Thanks, OnePlus!
This one on eBay should do the trick https://www.ebay.com/itm/275420607111?ch...
This guide should help as well https://www.youtube.com/watch?v=FsZFyGXc...
这个答案有帮助吗?
得分 2
4条评论:
Oh wow, that's odd. I would've thought that with the sensor being in-built that it would just be plug and play like the display and literally every other capacitive thing with it. I haven't tried the usual troubleshooting like rebooting and such (and I'm not factory resetting this phone unless I'm selling it). Guess I'll see where the links you provided get me. Is that same tool available on Amazon by chance?
由完成的
If you can register new prints have you removed any old prints then tried again?
由完成的
@razorx you'd think it would work like that but no. I haven't seen it on amazon but it's worth a shot to check
由完成的
How can you reprogram the fingerprint sensor?
由完成的
添加一条评论
OnePlus said that no calibration is necessary after installing a replacement screen and digitizer on the OnePlus 8 Pro. Current as of 06/10/2023.
这个答案有帮助吗?
得分 0
4条评论:
@schleems18 it must be necessary surely. Otherwise how does my fingerprint register fine but never works in practice?
由完成的
I haven't attempted changing or adding a new fingerprint, everything functioned as it had before the screen replacement. Have you tried a factory reset? You could also try adding the same finger a couple times, just in case.
由完成的
@schleems18 I'd much prefer not factory resetting, I don't want to go through the faff of recovering everything. And I did try adding a couple times, no avail. As of late I've just been living without it
由完成的
I'm facing the same issue
由完成的
添加一条评论
phone display not on
这个答案有帮助吗?
得分 0
1条评论:
how to on phone dispaly
由完成的
添加一条评论
Fingerprint issue
这个答案有帮助吗?
得分 0
1条评论:
Fingerprint scanner issue
由完成的
添加一条评论
Will it work after a hard reset??
这个答案有帮助吗?
得分 0
添加一条评论
I have faced that problem after display Replacement in oneplus 8 pro. Any solution here plz?
这个答案有帮助吗?
得分 0
添加一条评论
fingerprint not working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Razor X 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 58
总计 10,149
