跳转到主内容
A 10 speed mixer made by KitchenAid in 2006.
29 个问题 查看全部
Can I bypass the control board to test the motor?
I bought a used mixer that isn't running and would like to test the motor before I invest in a new control board. Is it possible to temporarily bypass the control board to test the motor? I have already ruled out a short in the power cord.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@eraskin yes it is. Use thios guide KitchenAid Professional 600 Drive Motor Replacement and disconnect the motor controller from the motor. Then apply power directly to the motor. How you accomplish that, will depend on what you have available. I would use test leads with alligator clips, and come of the main power supply from the mixer. Of course, you can also just take a stripped power cable and use that :-) Whatever you got .... It'll buck since it will get a full load so make sure everything is clear in the transmission etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Evan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 185
