跳转到主内容
camera not turning on when charged, battery is stuck inside
basically, this sat on a charger for two days, and i had checked it every once and a while
i don't think this was used after about 2016-2015ish?
i tried to remove the batt, but its like stuck inside of the camera (im assuming by corrosion, as it sat in a basement for 8 years or so)
help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
@timtomissus "his sat on a charger for two days" most likely a dead battery. Take a pair of hemostats or similar and try to pull it out, or you could pour some high-grade isopropyl alcohol into the battery holder and see if that releases it. At this point, most of the damage will already have been done. Use something like this teardown Kodak EasyShare DX7590 Teardown - iFixit to disassemble it and see what is going on.
这个答案有帮助吗?
得分 0
3条评论:
@oldturkey03 they* thanks :)
完成的
@oldturkey03 also i should mention that its charging dock doesn't work either, the light doesn't light up, but i think some deoxIT should fix that, as its really dusty lol
完成的
@timtomissus maybe it's not working since it is not recognizing a battery? Cleaning will definitely be a good start :-)
完成的
添加一条评论
添加你的答案
timtom77 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 345
