跳转到主内容
The Canon PowerShot SX160 IS is a 16.0 megapixel digital camera with a 16x wide-angle optical image zoom and a 3.0 inch LCD.
25 个问题 查看全部
Camera from flea market with bad corrosion
I recently bought a canon powershot sx160 IS from a flea market and the batteries were so bad corroded, I think some leaked into the internals.I opened it up and saw some light rust on the corners, but I dont know what parts to be careful of. Is there any way recommended to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@andrew27242 it would be nice if you could see what you see, so we can be way more concrete with our answer. You can post images with your QUESTION. Just edit it and add those Adding images to an existing question - iFixit Repair Guide
In general, you can remove the corrosion from the battery by simply using a cotton swab and vinegar. Use that on the contacts etc.
If it is rusting on the metal parts vs. the blue looking corrosion caused by the alkaline battery, then get the smallest can of rust remover at your local automotive or hardware store (Rustoleum and Loctite have a gel consistent remover that would work great). Use a cotton swab and apply it carefully. Let it finish its chemical reaction and then clean it with isopropyl (90%+) and a cotton swab.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andrew 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 38
