跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy A52 Is a Mid-Tier phone released by Samsung on March 17, 2021.
Where is the temperature sensor that stops the phone from charging
When I try to charge my phone, it says it is too cold, even though that's definetly not the case. I checked the sensor with "DevCheck" and it says it's -20°C. In some rare cases, it shows more °C and charges, but most of the time it doesnt.
So I want to replace the part with the broken sensor now and need to know where the sensor is. So...does anyone know?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
5个答案
已选择的解决方案
TLDR: It was the Main Flex Cable.
Since this is one of the first site that comes up when googling "Samsung A52s temperature too low" I want to share how I solved the problem. Thanks you everyone who I mention below!
How I solved the problem eventually:
I had the problem suddenly come up after 25 month of using the A52s (and therefore the phone was out of warranty). Phone randomly did not charge with the message "Temperature too low".
Using the App "DevCheck" as suggested by @milfie (Cost: Free) under "Battery" - "Information" the Temperature reading showed random False readings with the charging halting every time the reading fell below 0°C.
Using the iFixit Guide for the similar model A52 I changed the Battery (Cost: 15€ incl. shipping) as suggested by @timtomissus but the problem remained.
Then I changed the "daughter board" aka the "charging port board" (Cost: 15€ incl. shipping) as suggested by @oldturkey03 but the problem still remained.
Finally after a few month of the phone laying around unused I tried replacing the "Main flex cable" (Cost: 8€ incl. shipping) as it was suggested just recently by @zweligolowa in his short but genius reply "It is the flex cable" and this fixed the problem for me immediately.
If I had to do it again, I would do it in the following steps:
  1. Make sure its the same issue by installing DevCheck and checking the temperature readings.
  2. Try replacing the Main flex cable as it its the easiest, cheapest and most resource-saving of suggested repairs.
  3. Try replacing the Battery, as the battery has a limited lifetime and you profit from a fresh battery life.
  4. Try replacing the Charging port board.
  5. Report here for others :)
Best of luck.
这个答案有帮助吗?
得分 5
2条评论:
@nuclear_octopus Great write-up; thanks for coming here and detailing your experience so others can benefit from your learning! Much appreciated.
完成的
I have to register an account to upvote this! Thank you for your helpful answer, I was able to purchase a flex cable and replace it by myself, after that the problem went away immediately.
完成的
添加一条评论
最有帮助的答案
@milfie besides the excellent answer by my colleague @timtomissus and a change of the battery does not yield the desired result, there are more thermistors
The one for the charing is actually on your daughterboard. Sorry, did not have a great picture of it, but this should give you an idea of the location
If a new battery doesn't work, consider replacing the daughter board.
这个答案有帮助吗?
得分 5
14条评论:
@oldturkey03 teamwork!
完成的
@timtomissus and that is how we will get things accomplished :-)
完成的
Hey guys, thanks for your answers. I replaced both of them but unfortunately, it was neither the daughterboard nor the battery. Do you have any other ideas?
完成的
@milfie just to make sure, you replaced both the battery and the charging port. Still not charging?
Post some good pictures of the main board (both sides) and post those with your question. There might be further thermistors on the board.
完成的
According to the block diagram and confirmed by the parts list, it appears there are five thermistors, or temperature sensors, that are connected to the Sub PMIC chip and they're labelled AP_THM, BAT_THM, CHG_THM, PA_THM and WIFI_THM. Haven't been able to find an actual schematic diagram to confirm where those sensors are physically located, though. My best guess is that the BAT_THM and CHG_THM have been covered by replacing the charging port and the battery, but it's not clear where the others are.
完成的
显示更多的9条评论
添加一条评论
这个答案有帮助吗?
得分 4
1条评论:
@zweligolowa which one? Which flex cable?
完成的
添加一条评论
well, before you do that
have you spilled liquid on it?
have you tried cleaning the charging port?
also with the little googling i did i found this thread that says you should maybe try replacing the battery, as it could be the batteries' thermal sensor messing up, so i think you'll have to replace your battery
https://www.reddit.com/r/GalaxyA52/comme...
这个答案有帮助吗?
得分 2
2条评论:
No i did not spill any liquid on it.
I also cleaned the charging port already.
Okay, then I try replacing the battery.
完成的
I spilled some liquid on my phone and i tried changing the flec cable battery and the chargingport motherboard but nothing worked
完成的
添加一条评论
Most temp sensors are in the actual battery, you might need to replace the battery which is not a bad idea anyways, fresh new battery is always a good thing.
这个答案有帮助吗?
得分 0
3条评论:
@antoniomarchesi already been suggested and done so by the OP
完成的
Sorry, when I was shown the question there was no answers listed for it.
完成的
@antoniomarchesi nothing wrong with it :-) just wanting to make sure that you don't feel you are being ignored etc. Every answer is important.
完成的
添加一条评论
添加你的答案
Ferdi K 将永远感激不已
浏览统计数据:
过去 24 小时: 19
过去 7 天: 102
过去 30 天: 502
总计 15,708
