跳转到主内容
加入维修社区 - 创建账户
XPS 13 9360 是一款 2016 年发布的 13 英寸笔记本电脑,内置第七代英特尔处理器。它在 2017 年进行了更新,搭载了第八代处理器。
Battery Replacement problem for Dell 9360
I recently replaced the battery for my Dell 9360 using the Dell XPS 13 9360 Replacement Battery kit from iFixit, and it seemed to work fine for a few days, but now my battery doesn't seem to be charging properly. I followed the battery replacement instructions meticulously (Dell XPS 13 9360 电池更换). However, now my battery often gets stuck charging at odd numbers like 32% for hours on end (similar to this post: New 97w Battery Replacement - Not charging past 47%) and will last < 2 hours without being plugged in. Somewhat relatedly, whenever it is plugged in, the fan is usually whirring a lot trying to keep cool.
I made a battery report like the post above's answer by @jayeff suggested. According to it, I have a 60,002 mWh design capacity, and a 45,288 mWh full charge capacity. Are these two numbers sufficiently close to each other? Do I have a bad battery? Is this a calibration problem? Did I just buy the wrong one??
Any help is appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @matthewwhi66266
It looks like a bad battery.
Looking at the figures you posted it is only charging to 75% which is poor considering it is supposed to be new.
Contact ifixit about the problem and get a replacement.
这个答案有帮助吗?
得分 2
1条评论:
Thanks @jayeff!
完成的
添加一条评论
添加你的答案
Matthew Whitley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 539
