跳转到主内容
加入维修社区 - 创建账户
2004-2008 款 F-150 皮卡于 2003 年 1 月推出,作为 2004 车型年产品,是第十一代重新设计的 F-150 系列。
Misfire only when hot?
Once the truck gets hot hot it starts to have misfires in 5 and 7. Misfire typically only happens at idle after coming down from higher rpm. The upstream oxygen sensors are reading 15 for long term fuel trims. This meaning that we are lean in the mixture. I have narrowed it down to possibly dirty injectors, ECU, Dirty intake valve (sealing issue).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Was wondering if you ever got it figured out, mine is doing the exact same thing even on the same cylinders
完成的
It turned out to be the phasers, but I don"t remember exactly. I think we got lock out phasers.
完成的
添加一条评论
2个答案
已选择的解决方案
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
I'd say you could try to run some fuel injector cleaner through the injectors that could clean out any extra carbon build-up because if the fueling system is giving it that extra bit of pressure it could just push through the build-up but at higher RPMs, if's having trouble getting through the injector in the lower range then that would make sense. If you think it's the PCM you could get something to read what the PCM is seeing and how much it's demanding out of the injectors. I'd check battery voltage if the PCM is getting a few millivolts under what it should run the PCM could be in that sweet spot that it'll run the car and be on but at the same time be putting out a dirty signal then when you rev up the engine the alternator charges the battery and gives the PCM proper voltage. I would start with the fuel injector cleaner and check the battery voltage.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
NR26 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 1,491
