跳转到主内容
加入维修社区 - 创建账户
这是 Sony 13A multi-flip 笔记本电脑系列中 13.3 英寸型号之一。
Black screen fix possible?
This VAIO shows nothing on the screen. It works fine (including the touch panel) with an external monitor.
There's no faint picture either, so it's not just a backlight issue.
The screen connector shows no damage or corrosion.
Is it possible to isolate the problem on the screen's side or the mainboard?
Update (04/11/23)
A new screen is not available for purchase and it would probably also be prohibitely expensive to buy one. It would be cheaper to find another used laptop with a working screen.
I disaseembled the screen as per the instructions to see if there is an obvious fault, but all connectors looked fine and there was no corrosion or burned parts. The test points on the PCB measured the correct 5V. I suppose it's possible that there's a bad connection in one of the ribbon cables.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
If it has a HDMI then connect it to you tv or a screen?
由完成的
Yes it does.
由完成的
添加一条评论
1个答案
最有帮助的答案
you should get a new screen to test if its the board or screen at fault.
i don't think it would be a board issue as its connecting to the monitor, but this would be telltale sign if it was a screen or board issue
https://www.amazon.com/KREPLACEMENT-Repl...
Sony Vaio Fit 13A SVF13NA1EL 屏幕更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
naujoks 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 513
