跳转到主内容
加入维修社区 - 创建账户
Adhesive tapes LCD replacement
Hi,
I can't seem to find the adhesive tapes to remove the LCD screen from the panel to put a new one. I have a HP 15s fq0071.
On the top it's not there and I don't see them at the bottom.
Please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I was ready to give up when i finally found the adhesive tape hidden behind the hinges. (most videos says it sticks out bit this wasn't, neither at the top or the bottom but hidden). See pictures
With bleeding fingers and nails and tools stuck in between like dentistry I managed to grab it. And slowly pull it out.
Now I will look for the parts to replace it.
Thanks all who tried to help.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi @tma2020
Here's the maintenance and service guide for the laptop series for your model.
Go to p.50 to view the procedure to remove the display assembly and then the LCD panel.
The HP part number for the adhesive tape is L52528-001 (supplier example only). Search online using the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
2条评论:
The part was L63567-001 in the end. But thanks for that maintenance guide. It will help in future.
Thanks all
由完成的
شكرًا على دليل الصيانة
由完成的
添加一条评论
添加你的答案
Tma2020 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 51
总计 1,340
