跳转到主内容
加入维修社区 - 创建账户
XMAX V3 Pro 是一款来自 TopGreen 品牌的干草本笔式汽化器。
How to repair heat sensor error?
The vape does not heat up, it always displays the heat sensor error.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
You can try to remove the battery and put it back in, that has fixed the sensor error for some users. If that doesn't fix it you might have to reach out to the manufacturer. I'm pretty sure the warranty is 12 months from purchase.
这个答案有帮助吗?
得分 0
添加一条评论
Hitting and smoking not working
这个答案有帮助吗?
得分 0
1条评论:
Not sure but could be something wrong with the contacts or temperature probe
完成的
添加一条评论
The other Day i had the sensor error.
It happened when I was outside at night, not freezing but it was pretty chill.
After carrying it a few minutes in my hand, with a few times turning it on, it worked again.
Today I found a statement from somebody claiming to be representing XMAX at the fuckcombustion forums.
This behavior is no bug or malfunction, but a security feature.
18650 Batteries don't perform well, when too cold.
You just need to warm the device a bit and it works as supposed.
这个答案有帮助吗?
得分 0
1条评论:
Today the error happened again, while indoor and it couldn't be the "too cold" protection.
I took the Device apart, for the Coil, the Thermistor and the + Wire you need to solder.
In the actual heating chamber is a mesh-coil and one of the contacts just barely touched the mesh.
I have not put it back together yet, its really finicky and takes a while to fiddle the wires through the different holes.
In this picture you see the bottom of the heater with the 4 wires.
The two thicker wires with translucent insulation are from the Coil
https://guide-images.cdn.ifixit.com/igi/...
完成的
添加一条评论
添加你的答案
[ Bor ] 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 101
总计 4,656
