跳转到主内容
加入维修社区 - 创建账户
Game Boy Advance 游戏卡带(也称为 AGB-002)的维修信息。
Putting a fallen chip back on
I opened up my pokemon sapphire cartridge up to see what was wrong with it after a long time of absence and discovered a chip came right off.
i have no soldering experiences so I would have to go in this repair blind. So i want to at least ask if this level of damages is fixable or not.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Oh. Well that's kind of a bummer. And would definitely cause your cartridge to not work. Since that's flash memory. So That would be where actual game data is stored.
Lucky for you, it looks like the board itself is intact? I think? I can't tell what the solder pads on the right side look like for sure because of glare in the picture.What we would really want to see is where the chip came free from the board. And the legs on the chip can be fragile, so as long as those are all intact, probably a straight forward job.
This will definitely take soldering skills to fix, but is not super difficult (compared to other SMD level soldering jobs) with the right set of tools and some practice. But it's definitely not a soldering project I would go into with flat out no experience. It also looks like it could just use some cleaning in general. But it looks repairable to me. Although I'm not sure what might have caused it to begin with (probably time and getting knocked around).
这个答案有帮助吗?
得分 2
添加一条评论
provided that the leg damage is minimal, a good technician could try to bake the chip back onto the circuit. Problems are going to include: all plastic needs to be removed (it will melt). that battery needs to come out (it will burn).
Is this something you could do yourself? No. It requires SMD soldering and the skill to perform it.
Is this something which would be simple? No.
What might it cost to pay someone to do it? Maybe $50.
What is the likelihood of positive repair: Low.
What other options do you have? wty replacement. You could find someone at Nintendo, petition them for merci, send to them the chip and plead a case for a freebie. (a new replacement)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sandbag 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 27
总计 651
