跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
LCD Screen, which cable does what?
The LCD screen assembly has 3 connectors.
What I want to know is which cable is for what?
One of the cables will be the digitizer, one the LCD DATA and one the Backlight power.
Which is which?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Here is a site that has the tear down of the 3Gs: (The link is messed up so you have to type it in by hand. Sorry. ) See image above
http://www.rapidrepair.com/guides/iPhone...
Look at photo with step 2. If you click on the image it shows item #1 is LCD Screen, Item #2 is digitizer. I would guess the last one ( under #1 & # 2) would be your backlight power. (guessing)
The 3G looks to be the same as far as these spots indicate.
Hope this is what you needed.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for that!!!
完成的
添加一条评论
Take a look at the tear down. It should show you what you're looking for.
iPhone 3G Display Assembly Replacement
这个答案有帮助吗?
得分 0
1条评论:
No actually it doe snot say which cable is which. Just that they are there and labeled 1 2 and 3.
I want to know which cable is for what.
完成的
添加一条评论
if the answer has not been given by anybody, I may add tha cable 3 is for ear speaker and sensor that black out screen while listening to a call. Saeed Jabal
这个答案有帮助吗?
得分 0
添加一条评论
#1 LCD Screen
#2 Digitizer
#3 Ear Speaker
#5 Headphone Jack
#6 Wireless
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ViriiGuy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 11,233
