跳转到主内容
加入维修社区 - 创建账户
iPhone 3G Display Assembly Replacement
你所需要的
视频概述
  1. iPhone 3G Display Assembly Replacement, Broken Glass: 步骤 1 中的图像 1,3 iPhone 3G Display Assembly Replacement, Broken Glass: 步骤 1 中的图像 2,3 iPhone 3G Display Assembly Replacement, Broken Glass: 步骤 1 中的图像 3,3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    询问修复机器人
    添加评论
  2. iPhone 3G Display Assembly Replacement, Display Assembly: 步骤 2 中的图像 1,1
    • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
    添加评论
  3. iPhone 3G Display Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the metal handle from the suction cup. It's easier and safer to grip the suction cup's base instead of the metal handle.
    • Be very careful when opening the iPhone so that the cables under the display are not severed.
    • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
    • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
    • If the display assembly is too damaged to allow the suction cup to adhere, tape with a strong adhesive such as duct tape may be used.
    添加评论
  4. iPhone 3G Display Assembly Replacement: 步骤 4 中的图像 1,1
    • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
    • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
    询问修复机器人
    添加评论
  5. iPhone 3G Display Assembly Replacement: 步骤 5 中的图像 1,1
    • Continue to hold the display assembly with one hand, and use your other hand and a spudger to disconnect the black ribbon cable labeled "1."
    询问修复机器人
    添加评论
  6. iPhone 3G Display Assembly Replacement: 步骤 6 中的图像 1,1
    • Rotate the display assembly up until it is roughly vertical. This will allow easier access for disconnecting the remaining cables.
    • Use a spudger to disconnect the black ribbon cable labeled "2."
    询问修复机器人
    添加评论
  7. iPhone 3G Display Assembly Replacement: 步骤 7 中的图像 1,1
    • Use a spudger to flip up the black plastic tab holding the remaining ribbon cable in place. The black will rotate up 90 degrees, releasing the ribbon cable.
    • The tab is very fragile, so be careful when flipping it up to unlock the cable and down to lock the cable.
    • The plastic tab may be white (instead of black) on some iPhone models.
    • Slide the ribbon cable out of its connector, and remove the display assembly from the iPhone.
    添加评论
结论
取消:我没有完成这个指南。
229等其他人完成本指南。
1指南评论
i went through the whole process, but my home button does not work anymore. it was fine when I started - its it possible, that one ribbon is not fully attached ore is there any other solution? Thanks for any advice!
Jakob
JakobBartke - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 94
总计 305,348
