跳转到主内容
加入维修社区 - 创建账户
13 英寸 MacBook Pro 于 2020 年 11 月发布,配备 Apple 基于 Arm 的 M1 SoC,具有 8 核 CPU 和 8 核 GPU。(型号 A2338 / EMC 3578,带有两个 Thunderbolt 3 端口)
Service Recommended: MacBook Pro m1
Hello! I just changed the battery of my macbook pro m1 and I get that error. I have restored the MacBook and nothing. The battery seems to work since without the power cable it works fine, however I can't see the percentage and I get that error. Can somebody help me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Where did you get the battery? Also are you sure you needed to replace it? This is a young system which shouldn’t need a new battery yet.
完成的
添加一条评论
1个答案
When you go to System Settings -> Battery, what do you see? Can you see the percentage there? If so, you should let the battery charge to around 100%, then let it discharge to around 10% or so, then reconnect the charger and let it charge up again to 100% to see if the message goes away after putting the battery through a full charge cycle. You could also try booting into Safe Mode to see if this fixes the issue. In the worst case scenario, there may be a defect with the battery you installed. Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Borja 1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 460
