跳转到主内容
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
How to repair my psp when can't on power
my psp 1000 can't on and when my battery full also can't working....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
3条评论
I have the same problem too!!
I checked the batery, the power is connected to the motherboard.
完成的
How do I do that
that
完成的
i have problem with my psp start and l buttom
完成的
添加一条评论
3个答案
最有帮助的答案
Look at the DC port on the PSP. Does it have the little metal pin sticking out of the middle? It is also possible that the switch on the power board may no longer work. Pick any of the guides listed on here PSP 1000 and open the PSP up and see if you can hold the power board still, plug it in and try flipping the black switch to see if it'll turn on that way. Of course there is also the possibility that your power fuse is blown and that you have an interrupted circuit. check on here for much more info about that. Hope this helps, good luck.
这个答案有帮助吗?
得分 7
7条评论:
i will try it....thank for teching....
完成的
but me is 3006 modal...can help??
完成的
ginz.. this is the guide for you PSP 300x, I'm not sure that the fuse is in the same spot..If you need further help then please start a new question.
完成的
where the 300x fuse and i think board spot...
完成的
uuuum...Does this work on Non-Sony PSP...cause my PSP is not sony
完成的
显示更多的2条评论
添加一条评论
check the batery and the power on button.
这个答案有帮助吗?
得分 2
添加一条评论
I had seen on Youtube if you repeatedly push up the power button, it might turn on. Worth trying
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ginz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 115
总计 37,508
