跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad X390 Yoga 的维修与故障排除信息。
Replacing the USB-A Port
Can the USB-A port be replaced on this model, and if so, what parts are needed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @brian46050,
Which USB-A port (aka USB host port) are you referring to?
There are 2 x USB-C and 1 x USB 3.1 on the left side and a USB3.1 on the right side of the laptop.
They are all hard mounted on the systemboard so it won't be an easy repair.
Once you have found the correct USB connector (there are a few variations regarding mounting options - search on places such as mouser.com and digikey.com) the systemboard would have to be removed from the laptop so that it could be replaced.
This would require smd soldering etc. USB-C is harder because there are a lot of pins involved.
Here's the hardware maintenance manual that may help
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 612
