跳转到主内容
The Hisense 32H4C model is a 32-inch high-definition television with a light-emitting diode (LED) display.
Tv suddenly turned black screen.
Tv suddenly turned black screen. It has power on LED on, back black light on screen, and i can hear voice when i press the button on remote. But than that nothing work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
@rahulmahid31488 explain this "back black light" a bit better, First you need to verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a channel where you can hear the sound. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue. Also, verify that your TV is a 32H4C
这个答案有帮助吗?
得分 2
添加一条评论
请参阅图像内容:
这个答案有帮助吗?
得分 0
1条评论:
@lauramurengwa is this an answer or a question? No signal? Plugged the cable in?
Are saying you have some issues with some TV?
完成的
添加一条评论
Same but no sounds
这个答案有帮助吗?
得分 0
添加一条评论
If your TV suddenly displays a black screen, check the power connection, ensure the input source is correctly selected, and inspect cables for damage. Try restarting the TV or updating its firmware. If the issue persists, it could indicate a hardware problem, and professional assistance might be required.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rahul Mahida 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 124
总计 2,541
