跳转到主内容
加入维修社区 - 创建账户
Beats Studio 2.0 有线耳机的维修信息。最初于 2013 年发布。型号:BT OV STU BLK。
Power and charging problems
My beats when plugged in shows 4 led lights and won’t charge. It also don’t power on when I try to switch it on but still works with the wire
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello George,
it sounds like you are experiencing a problem with a worn connection port (that one you put the charging cable into). Delicate connections wear out over time and lose contact. The solution is to replace the port. You can do it yourself if you have skilled hands and a soldering iron (any delicate). Otherwise, find an electronic repairman or other "handyman"
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 20
总计 195
