跳转到主内容
加入维修社区 - 创建账户
2018 年推出的 1000 瓦总功率 5.1 家庭影院系统。配备蓝光播放器、内置 Wi-Fi 和蓝牙连接,可轻松进行音乐和视频流媒体播放。
Micom Options are lost
My hometheater not working properly. I figure out micom Options are lost. All the op0, op1.. to op5 are 00. Is there anyone who has these codings. Of you have the device you can see the options through (NO DISC or Tray OPEN State) and Setup-DISPLAY-TV Aspect Ratio16:9 Full 4+5+6+2 +5+8+0 +ENTER
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @sercantaylan
Have you tried a power refresh?
Turn off the home theatre if it is on, disconnect the power to the home theatre and then press and hold the Power button for a full 30 seconds and then release it. Reconnect the power to the device, turn it on and check the settings
If no good, try contacting the LG customer service centre in your location (ask for tech support) and ask if the latest software version is available for your model home theatre, either as a download link or an emailed file
If they state that you can update online using the settings in the device (Settings > Others> Software > Update) tell them that there are no settings available and that you can't do this.
Also if there is software available ask how to install it manually.
Just what I'd try
这个答案有帮助吗?
得分 1
1条评论:
I have updated but no change. I think the update doesn't make any change on eeprom :(
由完成的 分享
添加一条评论
添加你的答案
Sercan Taylan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 368
