跳转到主内容
加入维修社区 - 创建账户
纳米计算机是尺寸小于微型计算机的计算机。
What is this device?
Have this little box which I am assuming is a small computer, however I am having trouble identifying it.
I tried connecting it to an external monitor to no avail - it showed no output.
Thanks!
Pictures:
https://cdn.discordapp.com/attachments/1...
Added Pictures:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
Hi @computerashes
You may have to open it up and check if there's any info printed on the board, that may give a clue as to what it is and perhaps even a model number.
Does it turn on at all, even though there's no display?
Have you tried connecting a set of speakers to the green audio port to check if there's any audio if it does turn on - startup sound perhaps?
由完成的
@jayeff - Although a startup sound is a good place to start, If it's running windows, It's quite unlikely.
由完成的
@beanman56
Just covering all possibilities.
Cheers
由完成的
@jayeff - Okie dokie, I was just mentioning it was kinda unlikely.
由完成的
@jayeff I have added pictures of the interior.
It does appear to turn on as the indicator light activates and I can hear some light noise from the inside, as well as it lighting up the keyboard and mouse that I plugged into it however there is no display out.
I have tried connecting speakers to it, sadly no sound though.
由完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
@computerashes
All good.
FYI the device is an Intel D2700DC Apologies if you knew this after opening it up.
If you need drivers/BIOS updates etc then unfortunately according to Intel:
"Device drivers for Intel Desktop Board are no longer available on Intel Download Center after September 13, 2019. BIOS updates are no longer available after November 22, 2019."
You may have to try 3rd party suppliers
这个答案有帮助吗?
得分 2
2条评论:
@jayeff Thanks for that!
luckily it doesn't appear as if it requires any driver updates :)
由完成的
@computerashes
Here's the manual for the motherboard that may help.
FYI if it seems a bit slow using Windows due to 4GB ram limitation and an Atom CPU, try using Linux Mint (or any other Linux OS version that doesn't require much ram)
I resurrected an old Samsung netbook with a 2GB ram limit doing this and it works fine.
Just a thought
Cheers
由完成的
添加一条评论
最有帮助的答案
Could be a Intel NUC,
If It doesn't work, You could open it up and see if there are any markings inside.
这个答案有帮助吗?
得分 2
2条评论:
@computerashes - According to intel, it's a ram problem,
https://www.intel.com/content/www/us/en/...
由完成的
@beanman56 fixed.
It appears the problem was that it had a hidden security USB preventing the thing from booting.
由完成的
添加一条评论
添加你的答案
Computer Ashes 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 29
总计 465
