跳转到主内容
加入维修社区 - 创建账户
Flashing AE error and continually draining
My dishwasher is continuously filling water with a small steady stream from the side and then flashing the AE error code and draining, even with the water off, i have no clue where this water is coming from cause i have the water turned off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @alangutierrez
Check that the water is not entering the machine or being siphoned back into the machine from the drain by removing the dishwasher's drain hose from the drain.
According to most suppliers of parts for your model the tech sheet is part # 8535451.
The error code you mentioned is not shown in the tech sheet but try running the diagnostic tests as described by the tech sheet and check what errors it shows anyway.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alan Gutierrez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 27
总计 1,271
