Have a blown capacitor and am try to locate replacement part
So my daughters MacBook won’t power up so strip down and found a damaged capacitor but am not having much luck in finding replacement
This is where I would go Mouser - Polymer Capacitors
I’ll post the caps value when I get home in a half hour.
Here’s the needed cap Kemet 68uF 2917 20% ESR=50mOhm
And here’s the spec sheet Kemet Caps
这个答案有帮助吗?
Thank you for answer and links going to have a go tomorrow at removing the capacitor
@p5wnhgkxaopuehu that is reference designator C7373 which is a 68µF 16V 20% Poly-Tant capacitor in a D2E case. Check Mouser.com or Digikey.com for a replacement.
The case can be a hard match but a Mouser part number 80-T520D686M16ATE50 will fit and so will this one from Digikey.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 73
1条评论
Hi thanks for the answer and link going to have a go at removing tomorrow, use to removing eprom but never really tried capacitor that size before, don’t won’t to use hot air as some tiny resistors that are really close so maybe desoldering tweezers.
由 lukedash 完成的
