跳转到主内容
加入维修社区 - 创建账户
苹果公司于 2018 年 10 月发布的第 3 代高性能平板电脑。型号包括 A1876、A2014 和 A1895。
True Tone functionality after screen replacement
Hope all is well!
I’ve looked around other posts, but cannot seem to get a straight answer!
So going to the experts once again!
But iPad Pros, specifically the 2018 models, when the screen is replaced and the ambient light sensor is transferred successfully, does the iPad retain the True Tone functionality?
Thanks everyone in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
If it's anything like the iPhone, you'll need to transfer the screen serial number to the new display to keep true tone. There are tools out there for iPhones but I'm not sure about iPads. In some cases no tool may be available at the moment and may require you to transfer a soldered on chip(s) from the old display to the new one. If that's the case, you'll need someone that is skilled in micro soldering. This isn't a repair you can or should DIY unfortunately because it requires a lot of special tools like a microscope and hot air station.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jappleseed481 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 44
总计 837
