Is there a fuse there?
Where is located the fuse and how can I approach it?
Try the following methods to restore power to the Brother machine:
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
这个答案有帮助吗?
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 1,109
There are numerous fuses. Can you describe the symptoms?
由 Jim 完成的
The printer does not show any sign of life after an unclear power interruption.
由 tvarozna 完成的
