跳转到主内容
加入维修社区 - 创建账户
Other than the Tahoe Limited Edition, the vehicle was redesigned for the 2000 model year on the new GMT800 platform, still shared with the full-sized pickups and SUV's.
Having a problem turning it on
I recently had my Denali stolen and the thieves manage to mess up my whole ignition really badly … now my key don’t fully turn all the way and the only way to turn it on is by hitting a relay on the fuse box is there any solution to my problem …?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Most likely one of three possibilities. Attached to the actually key switch are two small usually light green switches, one may have gotten broken moved etc during the theft.
2: that particular relay has sticky contactors inside and needs to be replaced.
3: inside the steering colum cover at the ignition switch and gear shifter there is a stop the prevents the key from being turned to the run position if the shifter is not completely in the park position. I could have gotten bent or mis aligned during the theft.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
El gallo chingon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 320
