跳转到主内容
加入维修社区 - 创建账户
JVC KW-M650BT 是一款数字媒体接收器,配备 6.2 英寸清晰电阻式触摸显示屏。
AV Input is glitchy
Background: I am trying to hook up a nintendo 64 for the head unit. So far I can get a picture but it will constantly float up and reset. Ive tried different rca cables to no success.
Do you know of any way to not have the picture float away and be glitchy.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
@ricardocapriles Do you have a PAL or NTSC Nintendo 64?
由完成的
NTSC n64
-ricky
由完成的
@ricardocapriles Have you tried using another composite device like an SNES/NES or old camcorder?
由完成的
添加一条评论
1个答案
最有帮助的答案
The issue may not be with the cables, it may be ports on either the Nintendo 64, or on your media receiver unit. You may want to check the connections to make sure they are clean and don't have any dust or corrosion on them. If there is no problem with the connections, it is probably just something wrong with the video output circuitry in the Nintendo. In that case if you do have the technical knowledge you may be able to open the device up and attempt to replace any faulty components.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ricardo Capriles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 365
