跳转到主内容
加入维修社区 - 创建账户
Honda Fit(在部分市场也称为 Honda Jazz)是一款五门、前置引擎、前轮驱动的 B 级小型轿车。它由 Honda 制造和销售,自 2001 年起投产,目前已发展至第三代。该车型面向全球市场,在 8 个国家的 10 家工厂生产,到 2013 年年中,其全球销量已近 500 万辆。
2012 Honda Fit - Engine Compartment Fuse Box
Does any other year and / or model Honda share a identical Engine Compartment Fuse Box with my 2012 Honda Fit? Mine has 3 fuses, a 100 A for Battery, a 70 A for EPS, and a 20 A for Horn/Hazard (turn signals). The 20A fuse is blown, I can't see any way to replace just that fuse. I don't want to cobble up a blade fuse, so my only choice is to replace the entire box. I'm retired, so I don't want to pay the dealer price, so you see that means u-pull-it, the reason for my question.
Can anyone help me out, please?
Thank you for any help,
Jim K
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @jimknowles
Have you checked if fuses 23 & 24 in the under dash fuse block are OK and are the correct rating, as they are fed by the blown 20A fuse that you want to replace?
They are both 10A fuses so by rights if there was a problem with the hazard lights (#23) or the stop lights/horn (#24), they should have blown and protected the fuse in the battery fuse block before it blew.
Don't know about how to remove it, but according to the 2012 Honda Fit service manual the fuses are not serviceable - see image below.
(click on image)
Try searching for 38210-TK6-003 and see if you can find one for a better price than what the dealer is asking.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jim Knowles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 36
总计 1,370
