跳转到主内容
加入维修社区 - 创建账户
An Android smartphone produced by Samsung released in January 2017.
Samsung A5 2017 new battery.
I am using Samsung A5 since 2018. After putting a new battery, even if I don't use the phone, the charge drops from 100% in the evening to 60-70% in the morning. Same thing happened when I put in 2 new batteries. Is this problem with the battery or is the phone somewhere related to the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@lazizsamadov all this will depend on what apps you are running in the background. Everything your phone does, even keeping time will use battery power. You also could try and calibrate your new battery. Read more about that on here and here as well
这个答案有帮助吗?
得分 1
3条评论:
I closed all running backgrounds, put background apps to sleep as well. However, in the evening, the phone charge drops from 100% to 60%-70%.
完成的
@lazizsamadov did you calibrate your battery?
完成的
@oldturkey03 Yes, I tried, but it didn't help. I think the problem is where the phone connects to the battery.
完成的
添加一条评论
添加你的答案
Laziz Samadov 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 222
