跳转到主内容
加入维修社区 - 创建账户
为 PS3 原配手柄提供的维修与支持。这款支持六轴感应、锂电池供电的手柄(CECHZC2)于 2007 年 11 月(日本)和 2008 年(其他国家)发布,维修简便。
Why is 4 red lights blinking?
I recently took apart my DS3 and put it back together, ever since then I have received 4 flashing red lights everytime i plug it in. It does not give off any lights when unplugged
Edit: I have used the reset button and switched batteries.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Sounds like the board isn't connected to the battery properly and isn't charging. Open it up and check all the connections.
这个答案有帮助吗?
得分 0
9条评论:
Hey and thanks for answering! Shouldn't the controller work with unplugged battery whilst connected with usb?
完成的
@thimstr I don't think so. Usb is purely for charging and not actual power.
完成的
@strongbow Well, I switched with a brand new battery yesterday and I got the exact same results, sorry for not providing this info firsthand.
完成的
@thimstr obviously the battery is connected. Have you tested voltage to the battery connector with a multimeter with the cable connected? Check the voltage on the new battery too.
完成的
@strongbow Thanks for the suggestion, I would have to bring home a multimeter from work, is there anything else I could check in the meanwhile?
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Thim Strömberg 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 38
总计 1,889
