跳转到主内容
加入维修社区 - 创建账户
苹果第四代智能手表,含可选的蜂窝连接支持,2018年9月21日发布。
What is this part for?
I’m 13 years old and trying to take responsibility for breaking my Apple watch by fixing it myself.
I have the screen replacement, but this part came out of my watch. I think it is the force touch sensor, but I wanted to double check.
EDIT: My screen replacement is below. It is off-brand.
If possible could I get some help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you review Step 8 in this Teardown of the Watch you’ll see the pictured part is not the ForceTouch sensor Apple Watch Series 4 拆解
As to what it is would be tough as there is not enough information in the image to gain a sense of scale or understanding the parts construction.
Using the teardown can you see what it is.
Update (03/05/2023)
@ebp049x - OK, was out enjoying the day sorry for not piping up sooner.
The display assembly is made up of a collection of discrete elements the crystal glass, the touch plate, the OLED screen, the backplate which holds the NFC chip.
What I see is a bunch of mangled parts and you still have part of the display assembly attached to the watches body.
You will need to get a new display assembly to fix this. Here’s the guide which also has the parts info 显示屏更换
Apple Watch Series 4图片
指南
难度:
中等
Apple Watch Series 4 显示屏图片
指南
显示屏更换
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 0
7条评论:
It is part of the screen, which is not disassembled in the teardown.
完成的
That's the touch screen. Don't worry about it.
完成的
If I do not reapply it or do not purchase a replacement, will anything on the watch be affected?
完成的
@ebp049x That is already on the replacement screen. Nothing to worry about. Good luck with the repair.
完成的
I posted an update
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Eshaan Bhargav Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 427
