My Panasonic tv has a blinking red light.
My Panasonic tv code number (tx40es400b) has a blinking red light. It worked this morning at 4:00am before i left work, returned at 12:30 and this is where my tv wont turn on at all.
I have done the above
Unplugged everything, holding in the power button for resets, iv even taken the back off and there are no visible burn or swollen or blown parts.
How do i fix this as it was working this morning.
In-between me being at work and coming home the tv hasnt been turned on
8条评论
@gemmalinds24684 any patterns to that blinking light?
由 oldturkey03 完成的
The green led flashed quickly and then the red is a continuous steady red blink
由 Gemma Lindsay-sykes 完成的
@oldturkey03 managed to upload a video
@gemmalinds24684 so your TV shows 18 green and 5 red blinks but your TV's error codes only goes up to 13 which is an A-board (main board) failure. I guess we need you to post pictures of all of your boards, and you will need a multimeter. That way we can get you to check a few things. 在已经存在的问题里加入图片
由 oldturkey03 完成的
When asked for error code, i looked at some you tube videos to see exactly what i was looking for. In the red sequence it flashes once, and then a long pause, flash once, long pause. Looking for panasonic blink codes for one flash, i found this response:
One Blink: One blink of the facility LED indicates a drag within the inverter circuit located on the LCD panel. The inverter board isn't to be repaired within the field.
Therefore a replacement is required.
显示更多的3条评论
